Speedwagon
- Apr 8, 2008
- 4.0 V6
- Automatic
2002 Ranger supercab 4.0 4x4 offroad
Spring code on the door tag is 1K
For the rear springs, from what I'm finding, the K code is 2600lbs, which is obviously 1300lbs per side. The most common available spring seems to be a 1250lb spring. Will that make any difference in ride feel or stock height? I've found 1 place online that does show a 1300lb spring, but it's a bit more money per side as well.
Looking to replace the springs on this truck I just got, which has 180k miles on it. Rear springs seem like they are sagging a bit, and don't handle loads as well I believe they should.
