rear sliding window leak
grizzgreen
nj
i got a leak in my rear sliding window from around the top right side , it only does it on certain occasion like when it rains really hard or if its parked on certain angles likke up hill, it drips from the top making the floor soaked and soaks the ceiling , i no not good, the sliding glass part isnt stock its a replacement should i get another or whole new back window?
thanks ! i cleared out the drain port n it seems fine sparyed with a hose n no water, hopefully stays clear for a heavy rain haha
Mine is doing the exact same thing. I already replaced the light with a new one, but that didn't fix a thing. I called the local glass place and they told me 40 bucks an hour to reseal (guaranteed fix) and it would take 1-1.5 hours. I've also thought about putting one of the visors on the back to keep it from happening. Here's a link - they are in the middle of the page:
http://www.lmctruck.com/icatalog/fr/full.aspx?Page=89
By the way, what and where is the "drain port"?
The drain ports are built into the window it self. They are used if water gets inside the center sliding window track. There is one (looking from the inside) on the right of the sliding window and the other is on the far left of the sliding window.
Usually, if its getting the ceiling wet, it won't be the drain ports, but the window seal or the third brake light seal.
OK, this is what I was figuring the case would be but I wanted to be sure. Thanks!
