- Aug 6, 2007
- canyon lake tx
- Automatic
I would guess that it leaks behind the flywheel and down onto the bendix gear that is an inch or less away from the flywheel?
You wouldn't be able to feel the play in the crank. The only way to tell for sure would be to dissassemble the engine and plastigauge it.
When you pull the old main seal, inspect it for problems. Check how tight it fits the crank. It could be a seal problem because it is hard to buy quality parts anymore. The new one will probably be made in China.
I've never seen a Ford starter that didn't have a drain hole. It is at the parting line between the nose cone and the main housing. It is usually plugged with clutch material (on a manual).
