dblkbn
- Feb 28, 2009
- Automatic
The bottom latches on both rear doors will not hold the doors securely when closed (2002 Ranger 2WD). This does not appear to be an issue of adjustment- if I use a screwdriver or pen and push into the open latch it will close as it should, but I am able to pull the latch back open without using the door handle. The upper latches work as they should. The lower latches are a bit rusty, but nothing extreme. Lubricant has not helped. Is anyone aware of a fix short of replacement?
