Rear axle swap price?
why do i need new spring perches and shock mounts? Are they not ok as they are?
there fine other than on the wrong side
they are spring under, rangers are spring over
you need to put the spring perches on the top side of the axle. the ranger axle is spring over and the explorer axle is spring under. so you need to cut off the spring perches and weld them on top and cut off the shock tabs from the ranger axle and weld them on at a 45* angle or at a 90 and you wont have to get new shocks when you put in the explorer leaf springs. if you have any major questions just pm me
you need to cut off the spring perches and weld them on top and cut off the perches from the ranger axle and weld them on at a 45* angle or at a 90
What are you talking about? You need to set you pinion angle before welding on the spring perches. Best way to do this I find is to set the axle housing on 2 jack stands, use an angle finder and set the perches at 0 degrees and then rotate the pinion till its pointing upwards at 6-7 degrees. Recheck to make sure the perches are at 0 and the pinion is at 6-7 degrees.
the shock tabs i missed shock tabs some place fixed it now.
You can get an angle finder at most hardware stores for 10-15 bucks.
-plumcrazy
thats a lot more complicated than i thought but ill just take it one step at a time. Is there anyway to reset the leaf springs like getting them back to there original height? the ones on there are sagging a bit.
Do yourself a favor and grab the leaf springs from the explorer you are going to get the axle from. As long as it is a 4 door explorer.
Whats that do? Sorry about the hijack but This is new to me.
I am grabbing the ones out of the explorer but those are the ones sagging
Thank you for helping to support our economy....:headbang:
Totally unnecessary tho, I have 220,000 miles on my original 7.5 in my 89 B2. If it ain't broke....Run it!
thats what I'm saying....i've put my 7.5 through hell and back 4 times over. i've had it submerged in creek water, mud, sludge, on rocks, you name it and it has worked fine. i'm gonna change the front from that POS D28 when i get the chance.
now that i think about it, i guess that "POS D28" has been through the same hell as the 7.5 and is still ticking.
it's like the saying goes, if it aint broke, dont fix it....nobody said anything about upgrading tho
Lets see: $160 for the 1996 Explorer 8.8, $140 for ring&pinion, $260 for Aussie locker, $200 for new bearings throughout, $100 for perches, shock mounts, U-bolts & plates. So about $1.369 when all said and done.
any one else notice this doesnt even add up? :buttkick:
