Real Speedometer Issue, Please Help...
MikeGuevara
Alright, both my speedometer and my wipers went out at the same exact time around the end of last year. The wipers aren't a problem right now, but the speedometer is. And before you reply, the answer is yes to the following:
- It's not the ECU (I swapped my old one in and it still didn't work)
- It's not the gauge cluster (I swapped it old and put a different one in that didn't work either)
- I installed 2 new ABS/VSS sensors to rule out a bad one from the store
- The guys at the shop put 10 hours into trying to figure out why it doesn't work
Here's what I really need, I need to know what the ABS/VSS is connected to; running through; etc. starting from the sensor in the differential and running into the gauge cluster please. The names of any modules; boxes; relays; etc. would be greatly appreciated also.
1998 Ford Ranger XLT Flareside 3.0L V6
