rc lift
mattr87
roy, washington
im looking at buying a 4" roughcountry lift for my 87 supercab. it says it clears 33x12.50 tires with no rubbing or trimming of the fenders. has anyone done this?
yes and ull be fine with 33's aslong as they arent on stock backspaced wheels
Yes, although you can add some washers (or a spacer) underneath the lower coil seats to boost it back up.
Also, I would think wheels with close to 0 offset would be best. More offset will likely cause the tires to rub the fenders more.
i already got my tires mounted on some rims worse case senario i put on a bodylift or do a little trimming. and is there any special washers to use to lift it ?
