RangerAx
- Aug 13, 2007
Okay...let me start by asking to spare the "you can help the 2.9 by swapping in a v8" comments.
That being said...please tag along my little ride and detours to get to my point/question.
The other idea, amongst my frustration of the 89 sittin in the garage for a year and a half and at times, seemingly no hope of getting anywhere anytime soon, I decided that while I have no idea where money will come from to do things, maybe I could start tearing her down and prepping for some of the work I HOPE to do in the future.
While thinkin on it, I'm starin at the engine and taking mental notes of what I need to do and what I'd like to do and I'm staring somewhat blankly at the upper intake manifold when the thought crosses my mind about the throttle body from an 86 I had to crap because it was cracked and warped. I've actually spent time searching EBay for throttle bodies from just about anything that look like they might be somewhat compatible. In the past, I've been frustrated by the limitations on functioning cowl/ram air hoods and the like.
So finally a little closer to my point...it dawns on me that the upper intake is kind of ackbasswards...that is, air comes in the TB, down the upper and has to turn back on itself in the upper...when spoing, I realize .."hey, those down tubes on the intake are about 2" x 3"... "..so you can guess where I'm going I'd bet. So here it is: obviously I'm not real short on imagination..but I lack some of the tech savvy. I'm looking at this intake thinking about clearances and how could I build a new intake manifold short of casting (or should I say..build a redesigned upper). And it would seem to me that 2 x 3 rectangular tube with 1/4 or 3/8 plate cut and shaped to sit down on the lower, with pretty much whatever sitting on top of it, would replicate the outside appearance, with a more straight in approach, could be made shorter and customized. Then I start asking myself, what about all the other crap...the idle air control the vacuum lines...so here's the question for you guys and gals. It can't really be that simple can it..what would have to be done to make all those things work internally?
My thinking here is...if it's doable, KISS it, and make it easy enough to reproduce it, if not to sell it, then at least to be able to explain it to the next guy to go it (say on here..go figure of all places).
I guess what I'm sayin here is..edumicate me a little on the doability of this thought, yay, nay, maybe, you need to do this but not that, etc..and if it's doable, brainstorm on the best way to accomplish it? Cuz my brain is still stuck on ..2 x 3 uprights welded to 3/8 plates with a tube on top made anyway I want it....
