Rattle, rattle, rattle.....POP.
Mudhound
Solid Axle Swap
Eaastern Ky- out in the woods ( literally)
87
Yeah. 84 BII, tk5. Thought that the rattle that I was hearing was the throwout bearing giving up. Swapped it out, still rattled. Short test drive, on blacktop. NASTY crunchy noises in all gears. 5th gear actually lost forward momentum. Creeped home in 4th, best option, least noise. Rattle was in tailshaft housing/transfercase area. Big POP noise, now NO movement at all. Ideas?
I am thinking output shaft snapped due to bad bearing.
I thought the bii had a Mitsubishi tranny
Nope. The 84 came with either aTK4 or a TK5. I believe that the Mishitti trans started with either the 85 or 86 line up. Sure am going to miss the external slave, removable bellhousing setup.
