Rattle-can paint questions...
Doofy
Alaska
Shit Happens...Then You Die.
The old F-350 plow truck has problems with the paint popping off and leaving the gray primer exposed. I sanded most of the primer off, trying to feather the rough edges around the good paint.
I used a good self-etching primer and then about 3 coats of acrylic enamel. It turned out okay but is fairly rough.
My question is...can spray paint be wet sanded and how long must I wait for the paint to cure before trying?
Thanks, stvger. Can't do worse than screwing it up. Need to get some 400 grit paper.
i wetsanded my spray paint. well i rolled mine on but its rustoleum. its fine wet sand it then buff it...i used meguires ultimate compound on a cheap palm buffer
