Andy D
- Jul 9, 2011
- Marshfield MA
- My credo
- to prevent Found On the Road Dead, Fix Or Repair Daily
Rassen frassen Rat smells of gear oil and the RR is hot to touch. I suspect a frozen E brake cable. . I discovered this 20 miles from home., but drove home without incident. In fact, the hub was merely warm when I checked it. More later.
Harbor Freight float charger had the battery at 13.xx V. I have a V meter hitched to the battery to monitor how low the drops go. I plumbed depths of the radiator. !/2 full of cavitated coolant. No big deal, there is a full jug of 50/50 in the bed. The over flow tank and the buffered water temp gauge had me in a fool's paradise. It is a non pressurized overflow. Not an expansion tank This is incidental to the frozen brake issue.
I picked up the factoid about the over flow in passing here and decided to check. Just another leak to be monitored.
