Fawks761
Helloooo ranger station from the pnw wet coast of WA. I joined up because I have ambitions to put a ford 300 I6 in my ranger one day (this engine is still on a stand and in progress will upload the build later)
Is an electric pusher fan mandatory? Moving the radiator forward? Do all the 300's use the larger flywheel/bellhousing? If so, hammer work on the floorboard or a body lift required?Fits no problem going with carb or aftermarket Induction. Factory efi needs hacking of the intake or everything else.
Depending on year you have up to 40 inches to work with.
The second gen sport trac will eat a 6bt no problem. The 300 ford is about the line on the ranger.
Nah I haven't done so yet, mainly because I've not even started the rebuild of the ford 300 yet. I mean, whether it fits or not that engine is still gonna get built. Worse to worse if it cant be crammed in my ranger, I have a 1st gen Ford Lightning also. Could just have the 300 on standby incase I somehow blow that 5.8 351WHave you measured this yet? That is a very long engine and the ranger engine compartment is very short. I think it has been done before, but it's not easy.
