scdavis
- Jun 17, 2014
Hello, this is my first time posting in these forums.
I'm having an issue with my 1997 ford ranger 2.3L 5 speed not starting. I can push start the truck fine but when I turn the key, the solenoid just clicks once when the key is turned over.
So far I've; taken the battery out and had it tested by Autozone, Cleaned the terminals and replaced the positive terminal on the cable, Replaced the solenoid on the fender wall, troubleshot all wires with a multimeter from the battery to the starter. They tested fine. I removed the starter and took it to autozone and it too tested perfect. I'm running out of options here. I'm a broke veteran going to college so I can't really afford to just throw parts at it.
Is there anything I may have missed that it could be?
