monkguru
- Oct 8, 2012
- Automatic
Hello. I have been one here for 3 days now and my head is about to burst so I figured I make a simple post and hope that all this stuff in my head lines up. heh.
I have an 86 ranger 2.9 Stx. It recently started slipping. One question my manual says borg 1350 transfer case, yet I thought the trans is al4d? Is this one and the same, two separate units? The a4lf is supposed to have one electric conn the 3/4 shift solonoid. The borg 1350 shows many connectors. Mine has a 3 wire and 5 wire. But I dunno if thats the case/trans or what the difference is in relation to troubleshooting my problem. Anyway. *(holding my breath) Since I got the truck I was told to use D that OD had an issue slipping 4th. I tried it once and they were correct. Since I drove in D and had no issues. Now when I take my foot off the gas slowing from 3rd in D it slips when I go to step on the gas. I usually have to stop to resume. It shifts pretty good to second then 3rd and if I keep very light accelleration it doesnt slip. I tried to get codes and got 31 evp below min. and 89 clutch converter overide failure. The fluid has been a bit over full since I got the truck, so I just left it that way. Its a bit bubbly, but fresh and pink. I'm afraid this started cause I used OD to confirm it slips in and out of 4th as I get bad gas milage. Which it does. I do leak a bit of oil, but havent had to really add trans fluid or water. A few months back tho I seemed to have an overheating issue. I say seemed cause the temp only went bout between r / m in normal. But the truck did seem hot and stalled. I had to wait an hour before driving or it would buck like crazy. That was a few months ago and havent had the issue since. I was bout 104 out that day. Sorry for the long post, Ive just spent 3 days reading bout solonoids, bands one way clutches, vss and throttle sensors, modulators. I dont know where to start. many thanks to anyone that can put this into perspective for me.
