Ranger suspensio lift
racerjamie
Manitoba
Hi, Im due for new tires soon, so my question is to lift or not to lift. I currently have 31's, but like to possibility of 33's, im thinking of doing a 4" suspension lift, but i have questions on the available types. For the skyjacker 4" lifts, there is one with the longer trailing arms, which obviously increase articulation, im not sure if i want to go that far. If i did a 4" lift withour the extended radius arms would the truck still have decent articulation?
As well i had a question on switching to a solid axle, i have read that the ranger dana 35 is a reverse spinning gear set, are there any front ends out there that will spin this proper direction with the stock T case, i know Brendank69's has a dana 60 up front, but are there any other available, im thinking something out of a older ford 3/4 ton.
Thanks
Use the search feature, Bro. Lots of info on a lift for your truck.....
+1 You have a lot of learning to do. A simple search and or look in the tech library would unveil LOTS of information.
FYI, its called "reverse rotation" because the pinion gear is above the center line of the ring gear. A "standard rotation" will have the pinion gear below the center line. They both spin the same way.
