Ranger Rear leaf spring lift? please help
JACOBnco
I am very new to things so I might not know much lingo but I am looking for some serious help. One of the leaves on my rear leaf spring is broken. I want to replace the leaf springs with a lift. I don't want to use blocks and I would like better than stock leaves. I have found nothing on the internet that will fit a 2003 Ford Ranger 4x4 rear leaf, front torsion bars. I did however find "Superlift Suspension 90-01 Ford Explorer 4" Rear Leaf Spring" (http://www.ntwonline.com/Superlift-...rer-4-Inch-Rear-Leaf-Spring.html#.VEHN2vnF90w) Will these fit my truck? Thank you for any help. Like I said, I am very new.
Someone with more knowledge than I can tell you for sure, but from what I can tell '86-'03 RANGER springs are interchangeable. SDtrucksprings.com and generalspringkc.com have a few different springs for your truck, none that are advertised as lift, but they do have a heavy option.
If you are only doing a small lift in the front, you may want to stick with a block or shackle lift in the rear, or get new springs then an 'add-a-leaf' lift spring from Skyjacker. I am sure you could also get a single leaf from a larger truck to get the same result as the addd-a-leaf.
Yes, any 1983-2011 Ranger rear leaf spring is the same fitment.
Explorer springs will net you about 2" more lift than a Ranger spring, due to their greater arch and spring-under-axle placement (in other words, a 4" lift Explorer spring is much the same as a 6" lift Ranger spring)
