eagle121269
- Oct 19, 2013
working on 89 2.3 with dis ignition dual coils truck idles real eradic changed fuel pump egr valve changed plugs also changed one of the coils tried new computer fuel filters four new injectors cleaned iac valve while i was changing the coil i started the engine with the serpentine belt off it idled almost perfect put the new coil on put the belt back on idle went crazy took belt back off idled near perfect does anyone have a solution thanks also its a five speed truck
