D.J.
- Sep 24, 2009
I,m wrenching on a 1986 Ford Ranger and am pulling the five speed manual trans and eventually the V-6 to replace the freeze plugs in between the engine and trans. My problem is the iclutch hose that runs from the cowl to the upper left side of the manual. Haynes doesn't mention anything as to how to disconnect the interior clutch rod that runs from the pedal thru the the cowl into the master cylinder then into the hydraulic hose and on to the transmission. Any suggestions, please. Also the Kroil he is referencing is the BEST rusted parts breaker in spray made by KANO Labs in Nashville TN available at most old fashoned parts stores under AREO KROIL, KANO KROIL, and a couple more versions excellent for soaking exhaust manifold bolts and the like. Thanks D.J.
