dpbeard
- Aug 5, 2014
- Automatic
I just bought a ranger ext 4x4,The guy I bought it off of said the four wheel drive worked so I trusted him (he is my neighbor).I had to completley replace the entire rear brake system before I could drive it, so yesterday I was driving it home from work and it was raining and I decided to see if the 4wd worked.I turned the button and the light clicked to 4 hi. When I goosed it only the rear tires spun.Pulled off to a side road and tried it again nothing. got it home in the driveway and tried to put it in 4wd and the 4 hi and 4 lo light started flashing. I took the shift motor off hit the button and nothing happened I didnt hear anything coming from the shift motor.So I turned the transer case to where it said 4hi and pulled it out of the garage and still no 4wd.
Can someone please explain what you think is wrong may be multiple problems idk this system or how it works winter is coming and I drive an hour to work so I really need to get this fixed on a small budget
