ranger motor mount issue 351w
94BIGFOOT
n Royalton
i have a 94 ranger and have a 351w in a 4wd with 3in bodylift i am going to put in it i bought the advance adapter mounts, does anyone have a clear picture where they drilled and slotted the holes? the instructions dont really tell me anything
any help would be much appreciated thanks
Ryan
i usually use mark mounts and shim it up on one side with the drive train biased to the passenger side on the t case end.
i dont remember which holes i used for the aa mounts way back when. i hated them and went to a normal mount. but my ol crossmember still has the holes. its hard to tell looking at it.
maybe i can get a pic.
basically a mark 7 mount from like a 90 works pretty good, just needs shimmed depending on specific t case is its a 4x4 and headers/steering setup..
i will try and get some pics of mine. i will do the best i can cause they are on the truck. i just used the stock v6 rubber and used a flat plate drilled some holes and was off running.
i will try to get the k out yet today.
