Ranger Lift
rustyballs
Dryden,Ontario
I have a 4 inch ttb lift on a 91 ranger,can i change the i-beam drop brackets to 6 inch and get 6 inch coils,and use the 4 inch radius arm drop bracket, i ask is because i got a parts truck that has a 6 inch lift but someone took the radius arm drop brackets.thanks for the help
You'll just end up with some caster problems. An alignment may help a little bit.
You could also try to find extended radius arms.
you could call up the company and see how much the brackets are someone should sell them seperate, just get a part number
You can, but it puts more stress on the radius arm brackets. Could crack them...Ive had it happen.
