- Sep 7, 2013
- Age
- 56
- CA
- 2.3 (4 Cylinder)
I've have seen some newer Rangers with what looks to be black armrests on the deluxe door panels with map pockets. I like the look of the black armrests the way they blend into the black inside door handle bezels. Is the interior color called med/dark flint, Black ?
The 95/03 deluxe armrests had a problem with the vinyl and foam coming loose. Ford fixed this on the 04 and newer armrest and I have found they will work on the 95/03 door panel if you put fender washers on the three lower mounting screws. I want to upgrade my 97 Ranger to 04/11 black armrest. I'm just not sure what name Ford gave to the black color armrests. Does anyone know ?
Thank you.
Thank you.
