bigwhite4x4
- Jan 7, 2009
- Automatic
should i have any problems putting a 94 ranger cab on my 86 bronco II frame i know i've seen it done with the older cabs?
Look at teh two frames next to each other, compare them as Mark_88 stated.
you can find an earlier frame say, '74-'76 Bronco, now that would make a short Ranger an awesome setup. 9" rear, D44 front all setup, all kinds of lift options available.
I have a dana 44 up front out of a bronco and a dana 60 in the rear and the v8 swap so im to far into it to do that.
are any of the mounts going to line up it looks the radiator support are the same.
Is an older cab going to pretty much bolt on?
I went the stupid simple route. 91 regular cab on my 90 B2 frame. Only the rear most cab mounts need to be relocated. And the wiring was as easy as plug in and go play.
I would go with the extended cab on the bronco frame...there are pics of one on this forum somewhere or a link to it...very nice truck...only had to trim a bit off the back to make it fit too...
That is actually what I was thinking about doing at one time...
do you find the link i would like to see a picture of one
