v6Don
- Sep 20, 2008
- Automatic
I have a 1999 3.0 Ranger 4x2 with a 4R44E trans that I purchased a couple of years ago to do odd chores but also as a vehicle for my daughter to get around in. She has been off to college with it but recently came home with a range of issues that I have been trying to address.
She apparently ran over something that tore out the wiring on the back O2 sensor, and the ABS light was on. It wasn't shifting or running right plus the odometer wasn't working until you got to 25mph. Also the OD isn't working (no indication).
I replaced both the o2 sensor and the diff sensor. The ABS light and check engine light cleared but am still having issues with the transmission shifting.
The trouble is that there seems to be no first gear. When I start out, it has no power. Once up to normal second gear speeds it will shift from second to third. Manually shifting into first only gets me into second (shifting first to second and vice versa, I'm still in second gear at any speed).
This weekend I decided to pull the transmission pan and see what I had. The pan was clean and other than it being time to replace the fluid there wasn't any surprises there. No burnt fluid and in all pretty clean (no sludge build up on bottom of pan). I replaced the the filter and fluid. Still no first gear but shifting between 2nd and 3rd seems smoother (could be my imagination)
I've been doing as much web researching as I can but could use a little help pointing me in the right direction. Paying for my daughters college is costing me a fortune so any help is very much appreciated.
Thanks
Don
Thanks
Don
