Ranger 4.0 will not start
bere3
Ok so here is the story just got a 91 ranger 4x4 with the 4.0 ran fine had front end work done got it back ran fine then it acted l ike it ran out of gas put gas in seemd to be fine next morning would not start turn over strong nothing pump kicks on checked relay inertia switch they r in working order so i decide to put some fuel in the intake fires up ran like crap for a min but then smoothed out drove around for a while shut it off started back up nextmorning same thing but now getting nothing even adding fuel to intake not even trying im spinning my wheels here what went out?????:annoyed: thanks for any help
Bere3
Im having same problem just bought a 94 4.0L ran great for a month then yesterday didn't start wasn't even turning over or nothing I replaced the starter motor and now its turning over but not starting I know its getting fuel and spark plugs look fine so I don't know what it could be
Did you check your battery terminals? were they tight? If not that, make sure your starter motor cables are tight.
One other thing is you might have to replace the fuel pump. If your not getting fuel through the system, you ain't going anywhere
Replace your fuel filter. 15 bucks and probably needs done either way
ok where to start for past 2 days ihave replaced fuel filter tps, cam sensor, coil pack had control mod checked its ok checked pressure to the rail good pump good power to coilpack good but no spark checked all fuses good unless imway off base yhinking computer is not sending the pulse to the coilpack what else did i miss thanks for the post help i need it back on the road
Hello it's been awhile the no start problem was resolved it was a wire issue strange but was found in main wire harness I now have a new problem to go with the many I have dealt with not sure if it's a tranny issue or t case put a tranny in not long ago so think it t case for sure in 2 wheel drive while going 55 or less or more just cruising I get a popping feels and sounds like something is hanging up then releasing like maybe a gear is hanging up hard to explain but is an issue will the t case do that or is it a tranny problem
