Ranger 4.0 coil springs on a BII....
na i want to keep the fenders in tact.....
i think with the 4" suspension lift it will be fine....if it isn't, i have a set of coil spacers coming too....
ive actually had the problem reversed with 1st gens clearing fine but the tires hitting the bumper on a 2nd gen....idk just never ha d aprolem with them, where exactly is it rubbing, is it rubbing on the corner of the fenders, or is it rubbing on the inner fender well
it is rubbing on the lower rear corner of the fenders......I should have the lift on Friday if the shop can get it done then.....
its the rims then, if u had mounted them on stockers it wouldnt rub.
since the rims are different then that of the stockers as far as width and back spacing the central pivot point gets pushed out, which is causing the rubbing.
yea that is what i figured....i will have the lift on by next weekend and they will fit then!
