Trevor Dean
- Jan 23, 2014
This has been a minor issue for several months, but now needs to be solved. In the last 6 months I've replaced all the sensors on top of the intake, but not with Ford brand parts.
I have a 3.0 engine and a 5-spd (2wd). The proble occurs when I'm driving at any speed.
For example; I'll be driving at 30 mph, maybe 2K rpm, I depress the clutch to shift gears (up or down), and when I let off the gas, the 2k rpm will continue for 2 to 3 seconds, then drop down as it should.. The rpm should immediately decrease when I let off the gas, but it doesn't. Lately it will maintain the higher rpm for 2 to 5 seconds, then drop back. This is not an intermittant problem - it's always present when I drive the truck.
This makes for sloppy shifting and a few other minor problems, especially if the A/C is on. If his were a carbureted engine I'd be looking for stuck throttle shafts, sticking linkage, etc.
All the engine parts (linkage, etc) on the Ranger are in excellent and clean condition. I'm thinking the problem could be caused by one of the newer sensors near the throttle body, but don't know for certain.
I'm mainly an old-school type mechanic, so once I have the problem identified I can make the repairs. I don't want to just R&R parts to try and solve the problem. That would be a waste of money, and some of these parts are quite expensive. Maybe I should have bought Ford brand parts in the beginning?
Any assistance will be appreciated.
