carlitos1082
- Apr 7, 2016
- Automatic
Hi there
I have a problem and i hope someone can help me out, my ranger edge 2002 V6 3.0L automatic trans 2wd is having a hard start issue when the engine gets warm (driven for a while), when a try to start it, it will take 3 or 4 seconds cranking the key, and when it starts it will throw black smoke, i have no trouble to start it when the engine is cold nor black smoke, recent services are the following.
1.- Spark plugs and cables on July 2015 with 139k miles
2.- Thermostat and coolant on November 2015 with 142k miles
3.- Oil and oil filter on January 2016 with 144k miles
4.- Gasoline filter, ECT Sender and cleaned de MAF past weekend with 147k miles
Read somewhere on the net that this type of problem was because the ECT was going bad, that's why i repleaced it with a Duralast one, but the problem does not go away, got a OBDII scanner but no codes come up on the scan nor de pending ones.
Any advice is appreciate
Than you in advance
Than you in advance
