random warning beeper
The dinger takes the place of the airbag light as an audible backup if it is malfunctioning.
5 beeps 5 times is an airbag code. My light doesn't come on.
:bawling:
So you're saying replace the light, beeps go away?
i have the same thing. and it repeats every 45 minutes or so when driving. my airbag light was going off for a long time. the light went out and now i have the beep. theres a little black box under the dash on the passenger side up behind the glove box. i havent had a chance to tear into it yet but thats where the noise is coming from. its way the hell up in there though
Your airbag light in the cluster is burnes out they beep like that when the go out.
by any chance is it a 4x4? mine made noise when the shift motor went out, even when i put it back in 2hi it still made noise untill it sat for 10+ hours.
It's the airbag light. i replaced it, and have an airbag sensor out. so i just live with the light on for now. its better than living with with the beep.
...I have the same beep on startup and then after 30min I have the check engine light on and I think both airbags are deployed...I hate that stupid beep but don't want to tear it apart just for that!
My 95 had a problem with the beeper going off all the time.
Was told that there is a Master Control Module under the Dash that needs to be replaced, yup cut the wire...
Nothing has come of the beeper being cut out of the circuit.
Saved over $500 by not replacing the MCM.
Got rid of the truck after running it for 4 years without the beeper.
Funny... hah
