holyford86
Some guy with a problem
RBV's on Boost
GMRS Radio License
- Aug 6, 2007
- Age
- 39
- Plattsburgh
- State - Country
- NY - USA
- many
- Total Lift
- 7
- Tire Size
- 33x12.50R15
In recent weeks I have been having a high idle issue, along with pinging, I can't figure it out, it comes and goes quite suddenly. Here's what I've done;
-inspected IAC for cleanliness, removed actuator from the valve assembly, checked for free play and good seal, ohms tested the actuator and found it to be within spec (10 ohms). This IAC is less than 1 year old and is a OEM replacement
-Inspected and tested wiring leading to IAC, all checks out OK and the voltage values are correct.
-Inspected and cleaned throttle body and linkage, inspected linkage and cable for binding or wear.
-checked base timing (10* BTDC) right on the mark.
-Pulled KOER and KOEO codes found CM KOEO codes 54, 66 IAT signal high, MAF signal low (converted to '90 Cali Emissions so it's the right code)
-Replaced IAT sensor (it tested way off)
-Tested MAF with snap on MODIS, following the pinpoint test, Replaced bad MAF, tested new one, It tests within spec.
-checked for vacuum leaks, will be checking torque on the lower intake and plenum tomorrow but I don't think it's the issue, the motor was installed less than two years ago and was re gasketed when installed.
I'm still having the issue... I can't quite figure it out, quite perplexed. I have started pulling apart the wire loom under the hood and looking for corrosion and broken wires, should finish that up sometime tomorrow. This thing runs absolutely perfect otherwise, when it doesn't act up...
