radius arm length
jarfly
How long are you guys makeing radius arms? I know 12" 15" more, I can not find the lenght of the whole arm. Thanks for the help in advance.
I've made two sets now on my own (well, one set still needs finish welding). Both times I didn't work off a specific length, I just set it on the truck. Jacked up the front, supported the frame on jack stands, took the tires off and went to work. Both of mine I built the mounts and attached at the transmission cross member. Cut the existing arms to take 2"x2"X1/4" square tube and removed the stock mount. Positioned the square tubing, positioned the front axle, clamped, tacked, then cycled the suspension to make sure it was how I wanted it and welded it up.
Sent from my kite using a trebuchet
