radius arm bushings
funkingonutz
Enfield CT/LongmeadowMA/AgawamMA
Im about ready to replace my rad. arm bushings (because they are cracked and, the front end creaks when the brakes are applied) and i went online (advanced-auto-parts) to look up a price on them, and there were ones with adjustable caster, I just want stock replacment, this is the part number off the advanced-auto-parts website Part No. HB1495KHD They are made by TRW. here is the link:
http://www.partsamerica.com/Product...MfrPartNumber=HB1495KHD&PartType=2043&PTSet=A
Are these the ones i want??
Yes those are the ones you want. I've never heard of adjusting the caster with radius arm bushings, with the ball joint eccentrics yes. In the interest of time when you replace these; support the truck at the frame, unbolt the radius arm nut, and grind the rivits off of the radius arm brackets. Punch the rivits out, slide the bracket off and replace the bushings. Drill all the rivit holes to half an inch and replace with 1/2in grade 8 bolts. Much faster that pulling the rest of the suspension.
Matt
