rg2200
- Apr 15, 2013
I did some searching, but didn't find anything on this specific issue, so I figured I'd post a thread.
I have a 2005 Ranger, got it a few weeks ago, previous owner installed a JCV (KW-XR610) double-din head unit. Two problems:
1. Radio only turns on with key in 'run' position, not ACC
2. Radio isn't held in securely, and there's no obvious securing points for it.
Re 1, I took the radio out and backprobed the truck wiring harness - the BLK/PNK wire should have 12V in Acc and Run, but I only get power in Run? I know it's not good to leave the ignition in the 'run' position for long periods of time, but if I want to listen to the radio when the truck isn't running, I'd have to leave it in 'run'.
Re 2, I know this is a pretty open question and a million answers, but where the radio goes just doesn't seem to have any mounting points - I'm used to there being mount points on the side or at the back. For now, I just have double-sided foam tape on the bottom and sides to try to keep it somewhat in place.
