radiator hose
kisho121
my top radiator hose is about to fall apart. i had bought another hose but because of my 3 inch body lift it kinked. if anyone has a solution to the problem or an alternate hose from a different vehicle that works let me know.. Thanks a bunch
In the area that you need to compensate for the 3" body lift. Your body lift kit should of came with brackets to lower the radiator. Unless you got it second hand then measure the inside diameter of the hose, should be about
1 1/2 " . Go get a 6" section of exhaust pipe & 2 hose clamps ,then cut your hose in the straightist section & put 1.5" into each section of hose that you just cut,which will leave a 3" section exposed & solve the problem.
I bought one at AZ and I actually had to cut the upper hose to make it shorter. And that was with a 3in bl.
Said it was for a 88b2
EDIT: part# c70705
