Radiator Help
mountainkowboy
Socal Desert
Sucks to be you
OK, here we go, my 86 is starting to have cooling issues. The only radiators I can find are 1 row factory style replacements. Is there any place that makes a "desert cooler" radiator for it or a larger one? Any help would be great!
1991-94 4.0L automatic transmission radiator. There are a few minor retrofit issues -- mainly fitting the upper rad hose and securing the fan shroud.
But DO make sure your existing cooling system is working properly. A new radiator will not cover up a dead fan clutch or inop thermostat or rad cap.
Thanks, I forgot that the 4.0 is basically the same engine...............duh. Oh, and I've checked everything else, been a wrench for 30 years, but thanks for the heads up.
