radiator core replacment/ body lift
kris97ranger
Solid Axle Swap
lisle ontario
im in the process of replacing the core support on my ranger and while i had it all apart id like to do a bodylift but i cant get the very front bolts to slide out they spin inside the bushing but wont come out. anybody kno how to get it out?
________
Zoloft withdraw
At this point you are more then likely going to have to cut the bolts. And since you are replacing the core support you can repair it better/easier when you have the old one off.
alright so apparently ranger body mounts are waaay too complictaed i started by removing the top bolt through the rad support but it turns out the bolt going up from the bottom threads into a steel sleeve that spreads out kinda like a washer on top of the mount. i used a pipe wrech to hold it still and unbolted everything from underneath. also if u dont feel like doing way too much work i cut the bolts flush with the nut so im not undoing an inch of a half of unesaccary thread.
________
XexoticCarianeX cam
