Thanks man! I am adding a ton of gussets and added tubing to the door bars, bracing the A-pillar. I have had some close cells and as the truck becomes faster I realized it needed to be safer.
Truck handled 980000X better with the new set up. Sooo stoked, it was smooth through everything I put it through and felt way more solid with the cage bracing/structure.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
