ok people...I'm new to this forum and 2.3's in particular but I plan on racing an offroad truck in a division where you can only run 4 cyl. 2wd trucks.
I need your help to build a 2.3l SOHC with at least 150hp/150tq (thats what the chevy guys are prolly getting out of the 2.2l). Here's the rule book:
-Engine must use stock rods and crankshaft for that engine; rod bolts maybe replaced with ARP, crankshaft may be reground to stock stroke only
-Block maybe bored .030", stock OEM design pistons for that engine maybe installed, no forged pistons allowed.
-No lightening or knife edging or crankshaft allowed.
-No lightening or polishing of rods allowed, may be balanced
-Cylinder head must remain stock, screw in studs allowed, oversize valves allowed to repair worn seats, no under sizing of valve stems, no porting of head. Blending of bowl under valve for 1/4" to repair allowed, port matching of 1/4" to match intake allowed. Stainless valves allowed, must use stock stem diameter, no race flow valves allowed. Head can be resurfaced for clean up only, maximum machining is .075"
-Aftermarket camshaft allowed, maximum lift is .600 at the valve, roller, mechanical lifter or hydraulic lifter allowed
-Aftermarket valve train is allowed. No titanium parts.
-Any wet sump oil pan allowed, no dry sump systems.
-Internal engine mods are legal but remain factory stroke and a maximum of .030 overbore.
-Aftermarket internal engine hardware is allowed (ARP bolts, etc)
-Any header or intake may be used.
-Single cam engines may use aftermarket or fabricated intake manifold with one central mounted carburetor of a maximum 500cfm or 44 Weber carb with 42mm venturies electric fuel pump allowed
-Stock fuel injection is allowed. No aftermarket injectors, chips, etc.
-Dual cam engines must retain factory fuel injection. No carburetors allowed.
-Removal of smog equipment OK.
NO TURBO, SUPERCHARGER or NITROUS
What block, head, crank, pistons, rods, cam, etc. combination would you put together for this. I'd like to stay to a low budget with no real exotic stuff. Want to run carb and already have an MSD for a rev limiter. Thanx in advance and Sorry for the long post!
