Oldfish
- Aug 14, 2008
'89 Ranger, 2wd, 2.9v6.
Problem/s - Bad master cylinder replaced, cannot bleed back brakes. Also, do not get fluid out of RABS valve downstream (output). Before and since MC replacement, front brakes locked up and appeared to not have back-wheel braking. But when I really stand on the brakes in hard stops, the back brakes lock up -and then slowly let off... faster if I apply the e-brake and release. My conclusion from reading this forum is the RABS valve is clogged or bad.
My hoped for solution is to bypass the RABS unit. Not that I don't believe it is a good thing, but this is a farm truck that seldom sees pavement or speeds greater than 40. Also, the RABS valve at $115 (O'Reilly's) is worth more than the truck, and I just put $230 into rebuilding the transmission. Unfortunately, I also like the truck (mostly cuz my wife hates it).
So, the questions:
Does a bypass sound like a good solution to my problems?
Can I put a union between the RABS input and output linest?
What size union would this be? 3/8 inch?
Do I need to disconect any of the RABS wires?
Will this cause me any other problems?
Is there any chance of catastrophic brake failure while my wife is driving
Thanks in advance,
Oldfish
So, the questions:
Thanks in advance,
Oldfish
