2010_Ranger
So I'm planning on getting an engine for my 2010 4.0L sohc and I'm thinking it should be a direct swap with a gen 3 2011 4.0L? Only thing to caution is the ecm or what?
Thank you. Would it be reasonable to install an aftermarket oil pump to prolong a timing chain repair?I moved this over to the 4.0L engine forum.
You will likely just swap all your 2010 engine dress and engine harness onto a replacement long block. The long blocks should be the same.
Oh I've been thinking I had a 3rd Gen for sometime now hah. Thanks. But is there any other possible upgrades I could do during the swap. As far as I know an aftermarket oil pump for the timing chain?A 2011 should be a direct swap,
2004 to 2011 is 5th gen
Ford Ranger Generations 1983-Present - The Ranger Station
Generations are something that enthusiasts (not Ford) have placed on Ford Trucks based on body styling. Here's the Ford Ranger generations.www.therangerstation.com
Ok the engine is warrantied for 6 months so that's good to know.The biggest problem with the timing chain shannigans is lack of maintenance.
A new oil pump couldn't hurt a thing. The oil pan is two pieces and pump i believe can be changed by just removing the lower pan.
Caution... removing the oil pan would likely void any warranty on a used engine.
What's good for cleaning the oil passages? Transmission fluid or seafoam or something else?Not if the oil passages are plugged up from lack of maintenance.
