What part of the rear driveline? THe entire rear axle? OR the drive shaft or the axle and drive shaft? Swapping diff? most of it is pretty much the same. SHould be an 8.8 LS in the 04 and hte 94 has opendiff which will be fine, its just an improvment. I think there was a driveshaft difference but not 100% sure. Go the the thread righ tbelow the newbie threads its title Interchangeable parts of sumthing like that. Also read the tech library.
just swapping the drive shaft. i know mine is a two part D.L. im not sure about the 04. mine has limited slip too! lol the only reason im asking is because my rear u joint broke and when it hit the road it bent up the d.l so now the u joints wont fit in the holes. ill go look in that section. thanks!
For
