quick connect hydraulic clutch line
fatboy76
Jefferson City, Tennessee
I'M LOOKING FOR A PART NUMBER FOR THE CLIP THAT HOLDS THE LINE TO THE THROW OUT BEARING. I HAVE THE GOLD COLORED QUICK CONNECT WITH CLIP. I NEED A NEW CLIP.I HAVE TRIED TO FIND A PART NUMBER BUT EVERYTHING I HAVE FOUND HAS BEEN TO SMALL.I LOOKED AT CLIPS FOR THE FORD MUSTANG BUT FOUND THEY ARE SMALLER THEY HAVE BEEN RECESSED FOR THE SMALLER CLIP. ANY HELP WOULD BE GREATLY APPRECIATED. 1994 FORD RANGER 2.3 MANUAL 5 SPEED 2WD.
YES,IT HOLDS THE LINE IN THE QUICK CONNECT INSTEAD OF THE SPRING WHICH YOU HAVE TO USE THE TOOL THAT PUHES THE PLASTIC COLLER DOWN TO DISCONNECT. I'M TRYING TO FIND A PART NUMBER OF THIS METAL CLIP OR SOMEONE WHO MIGHT HAVE ONE.
I looked into this a while back, and was unable to find the clip for sale as a standalone part. It's considered part of the slave, and will come with a new clip-style slave. IIRC RockAuto was the cheapest option at ~$40. If you have access to a self-service junkyard, you can also grab one there. My yard would charge you somewhere between $0-2. It's also possible that any number of generic hydraulic line clips might work, but I can't confirm any particular fitment.
Thought I might of had an old one , but I don't . The new style doesn't have that clip anymore. It has that plastic ring you push in to pull it out. Best of my memory so did that one. maybe someone has one laying around they can send you.
I HAVE THE CLIP I BOUGHT THE THROWOUT BEARING WITH CLIP NOW THE TRUCK I'M WORKING ON IS A 1994 RANGER 2.3 FOUR CYLINDER WITH MANUAL TRANSMISSION.I ALSO BOUGHT THE CLUCTH PEDAL SLAVE CYLINDER FOR THE SAME MODEL WITH NEW LINE AN CONNECTOR. THEY BOTH ARE GOLD IN COLOR BUT FOR THE LIFE OF ME THEY WILL NOT CONNECT.ARE THERE TWO DIFFERENT GOLD CONNECTORS FROM 94 TO 96?
Yes... compare the ends of the hoses you have. 88-92/93 and sometimes past that is one style, then they redesigned the quick connect fitting slightly.
