GregadetH
- May 17, 2009
- Automatic
Hi all! I've got a puzzling problem that I'm hoping some here can solve. I've recently bought a 1988 2.3 Ranger. Please bare with me as I'm not very mechanically inclined - yet.
I bought the truck with a bad exhaust system...no cat and an exploded muffler. It was running like it had water in the gas as well as smelling of rich exhaust. I bought a universal muffler and several clamps, adapters and even muffler putty to stop the exhaust leaks into the cab caused by the placement of the pipe where the converter was cut out. I've also changed the cap, rotor, wires, plugs and IAC. It still ran like it had bad gas. Mind you, I've gone through 2 tanks of gas and seafoamed the first fill up. Out of curiosity, I disconnected the O2 sensor leading into the manifold that was in front of where the cat should be. Now the bucking and rough running has almost stopped completely and the rich exhaust smell has gone away. I plan on installing a new cat when I can. My ultimate question is if there is no cat, would the o2 sensor cause the truck to run all wonky? It ran much better once I disconnected it.
Any help is greatly appreciated! Thanks!
-Greg
Edit: The electrical connector to my o2 sensor is pretty burnt as well. What is that a sign of?
-Greg
