QUESTION: doing a gauge swap
FO44RD
BERWYN, IL
I have a 1998 Ford ranger XLT 2WD with a 4.0 and automatic. It did not come with a tachometer from the factory.
Is the IP cluster from a similar year ranger plug and play or is a major nightmare to make the tachometer from a doner truck integrated?
Secondly I really prefer the gauge cluster out of a 2003 ranger specifically or and Ford Explorer SPORT, which have the contrasting white/grey faced gauges. Are these plug and play?
Finally, if it is not a major nightmare to make all this work, is there a company or person that could set the new cluster to the same mileage as the one currently in the truck?
THANKS4THEINPUT!
You can install a cluster from a '95-'03 Ranger or a '95-'01 Explorer. They are all plug and play installs.
Does anyone know of someone that recalibrates the odometers?
For that you will have to get yourself a PCM reflash or a SCT XCalibrator 2.
These are just mechanical odometers, NOT the digital ones on 2004 and later Rangers. Any input?
The '04+ speedometer cluster has completely revamped electronics. The odometer and trip odometer are digital. The '04+ Ranger's cluster will NOT work in a '03 or older Ranger.
