Question about using 30lbs injectors
Zero_Cool
I will be using some 30lbs injectors on my 92 RAnger 4.0L that I am swapping into my 87 BII, I have been told that you also need a calibrated Mass Air sensor to use the 30lbs injectors. My question is has anyone else done something like this, and if so where did you source your calibrated mass air sensor from, as I have been hunting around trying to find someone that makes them, but all I can find are ones for mustangs.
PS the other performance mods that I am doing are:
Cold air intake(BBK),
pace setter headers(ceramic coated),
ported intake manifold,
Russell Steel braided fuel lines
custom tune on ecu to get best performance running 87 octane
I think you'd be wasting time and money to add 30's if your not putting a power adder on it. Stock injectors should be plenty for the 15-20 extra ponies you will be adding with those mods. If you are putting on a turbo or supercharger and going to a tuner anyway then bigger injectors will be necessary.
