today i was recovering refrigerant from a car and the machine was in the clear lines phase and the moister indicator started filling up with some white milky looking stuff. it seems to be liquid. i shut the valves off and stopped before it started recovering, but i looked at the flow diagram for the machine and it would have gotten into the tank no matter what i did.
what i need to know is if anyone else has seen this stuff and knows what it is and if its miscable with r-134
the reason i ask is because the tank is full of new r-134 and my boss doesn't want to waste it if possible.
i already have to take the whole machine apart and flush the system out and if i have to i'll be draining the tank and cleaning inside of it
another question. does anyone know if i can use the recycle function of the machine to just filter this shit out? we can sacrifice a filter if we need to
edit: just thought i'd add that the car i was recovering from had a plugged up system, the low side sucked into a vacuum while the high side went 250psi+
the machine is a robinair 34700 and i haven't found info using google
