Question about doors
fleck
Florida
Alright so I already found out that the Ranger and B series doors are the same pretty much from 92 to 2002 or whenever, but I have another couple of questions.
First I was wondering if I can plug-n-play doors with electronic controls to my truck with manual everything or if it would be easier to swap the internals. There are a couple of Ranger 99 or 00 doors going for cheap locally but they are electronic and I was wondering if I'd need to do any modification or run any wiring, etc.
Any help is appreciated.
I would PAY to see someone fit 92/93 Mazda doors on a ranger. To fit doors with PW, PL and such you'd have to do some wiring as you wont have fuses for them. if you were to find the wiring diagrams, you could hook them up but if your not good with electronics, just swap regulators/ find non power doors.
Why would you pay to see that? The Ranger and B series have the exact same doors (not to mention being mechanically and electrically identical as well). The only thing that's different is the front end (grille, bumper, hood and corner lamps) and the tail lights and bumper (and the Mazda logos). Thanks for the info, I've been told I'll need to run wiring for electric doors so I'll be looking for a door with manual controls.
Well I'm obviously going to make sure that it's the same door before I put it on, but I'll just guess that their search database has it wrong and they thought it was 93 instead of 94.
The 1992 Ranger doors are different from the 1993 doors; as in 2nd generation versus 3rd generation trucks. The 1993 and 1994 doors are the same, except that an internal side impact beam was added in '94.
If you're looking at swapping over to electric locks and windows, the 1993-94 doors would be MUCH better to use than the 1995 and up doors. Through 1994 the electrics are old-school switches and the connecting wiring harness. Starting in 1995 the electrical accessories are controlled by a Generic Electronic Module (GEM), so the wiring becomes a lot more complicated. Non-GEM donor doors wouldn't be nearly as difficult to wire up if you're wanting to convert to power locks and windows.
Externally trim-wise, I know that at least some Mazda doors (perhaps Super Cab only) have a blacked-out area around the glass, with chrome strips, that's different from the Ranger.
Hope this helps, and good luck.
Awesome, thanks for the info on electronics. I really wished I could have gotten at least a 96 but ah well.
