Some MIS-info here.
A Ford T-5 is a Ford T-5, the only difference is between the 4 banger and V8 trannies and the input shaft pilot bearing diameters, and all that requires is a Bushing/bearing change. Other than that it is just gear ratios and gear material. A mustang T-5 will work with a Tbird bellhousing, or vice versa, 2.3 or 5.0.
An M5OD is NOT stronger than the T5. There is A LOT more T5's, Both 4 banger and V8, holding big power out there than there is M5OD's. The T5 is built better, Shifts better, and has more aftermarket support than the M5OD. However the M5OD does have a better shifter position.
