Almost forgot 1997 ranger 4.0 Auto extended cab
I changed my Auto trans fluid /filter (80000)and now when I put it in drive reverse it immediately dies. Now what did I do?
Hints appreciated.
Okay here is a rehash of problem and what I propose to try and fix it. 1997 Ford Ranger 4.0 80,000 miles.
Bought truck used and have been changing all fluids.
Changed Trans fluid and filter.
Now once it warms up it will die in R or D.
Thinking about it and I remembered that the RPM's ALWAYS dropped to about 500RPM in reverse even before fluid change...Important?
Wasn't thinking when I pulled pan, but there was a chunk of metal in the pan. About 3/8" wide x 1/4" tall x 1/16" thick. looked like a tab that broke off something. Couldn't find anything (didn't know where to look). Now I think it might be the bracket that holds the solenoids. I will check when I dropp the pan again.
What my plan is:
Drop pan and VB
redo the VB with the Ford TSB
Superior boost kit?
Change the TCC and probably the EPC (the truck has 80,000 miles).
Put it back together and see what happens.
Any other ideas or suggestions are appreciated.
