pushbutton 4wd backlighting
rkneeshaw
Northern Michigan
Anyone know if the 4x4 pushbutton switch in pre-95 rangers was ever meant to be backlit?
Lots of driving at night during the winter time and I have to feel for the button, just curious if I just need to replace the bulb or get creative :)
Yes I have a 1993 and its lit, It has two led.s one behind each button if your aint lit someone messed with the button and moved the led.s Just pull the dash out remove the button assembly and realign the led's. If htey dont work they may be burnt out which led's are cheap to replace, jsut a pita to solder.
So you're buttons light up green when you turn on the headlights?
I'm not talking about the orange lights next to the buttons, those work fine on my truck. I'm looking to light the buttons themselves.
OH no mine light up orange when activated If you want them green get your self one of them green led sets and wire it up to your dashlight panel, even then the button might not be se through so you might need to razor knife it or somehting.
The lettering on the push buttons are supposed to light up green when the headlights are turned on. I believe, if I remember correctly, there is a 194 bulb in the assembly. Just pull two screws at the ashtray and yank your bezel off. Next, unplug the 4x4 switch. Then you can pop it out by depressing the two tabs on the sides that hold it in the bezel. You'll find your treasure in there..
on my 93 they dont light up green nor do they have a place for bulbs, but then again my hvac controls dont light up at all either.
the bulb that lights the buttons is a small bulb that has just the wires coming out of it. you bend them around the clip that holds it in.
first pic is the bulb next to a penny
the yellow circles are around the lights for the switch. two on the left are red leds for the indicator. right circle is the bulb to illuminate the buttons themselves
i took a blue sharpie to the bulb and the leds in the switch too. the bulb shines with a light blue marble effect. i havent tried the 4wd since so i dont know how the red leds look covered in blue yet but i'll add some pics when its dark
this isnt the best pic but dont bother trying to cover the red leds. the blue is real light but better than green, but the red clearly stayed red. the blue really only showed further away from the bulb. directly over the bulb stayed white
I've got the bulb out, noticed it has a green "condom" on it that obviously changes the light to the green color.
Now the problem I have is that I cannot find a replacement bulb ANYWHERE. None of the local parts stores, Ford dealership, even radio shack doesnt have one.
Personally I would look for an "led" replacement. Electronic suppliers such as Allied & Newark have them but I am sure you can get them cheaper on e-bay. Good LUCK
RonV :) :) :)
I'm learning: looks like I'm looking for a bi-pin base, probably a (EDIT: wrong) bulb size... I need to take another measurement of the burnt out bulb I have when I get back home. I think I'm going to have to put the voltmeter on this thing too so I can verify if I need a 12v bulb, or something else.
I'm all for going LED, but it looks like the way this bulb enters behind the pushbutton that illumination of the switch relies on light directed in a wide beam pattern from the bulb. LED's have a very narrow beam, which means it might only light up the 4 in 4x4 for example.
